Diesel Swap, beta phase questions
Old 11-05-2014, 06:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
DT360 Dry weight is 1200lbs
a 6.9 weighs 860
5.9 cummins 1,100lbs
Old 11-06-2014, 06:30 PM
87-XL-Squared's Avatar
87-XL-Squared
87-XL-Squared is offline
Thanks for sharing that, Brad! I really enjoyed that thread.
Old 11-06-2014, 06:42 PM
jrods2's Avatar
jrods2
jrods2 is offline
Smile s WHY IS MY ?
call Gear Vendors and get a overdrive for your trans auto or stick. They give you 8 speeds if you have a 4 speed or 10 speed for a 5 speed. If yourndoing 2800 at 60 you would reduce that buy using their conversion. Cost about $2500 considerable less than a swap & they can handle really high torque & hp. Increasing milage
Old 11-07-2014, 01:16 PM
ghanson's Avatar
ghanson
ghanson is offline
I don't know what sentimental value your truck has to you, but you're better off finding another truck that has everything you want. Like Brad said, the 6.9 is a safer bet that the 7.3, you never know if the PO checked the coolant enough and used the additives to avoid cavitation. The cummins swaps are awesome, but like everyone said, it will cost a lot, most likely more that the truck is worth, but the Cummins are great motors. Brad suggestion of the DT360 is cool, but alas it is more work, and from what I've seen, they're harder to find than the other motors. As for gear vendors, they're great, I'm looking to put one on my truck, but since yours is 4x4, the price I've seen is around $3,500 to $3,800 plus the cost of a new or modified rear driveshaft. But that will only give you a slight boost in MPG (I think they say about 20% on a big block). You'll still be burning more fuel that a stock diesel.
Old 11-07-2014, 01:48 PM
jrods2's Avatar
jrods2
jrods2 is offline
I have no plans to keep this diesel, got no use for it, work or pleasure any more. I pulled 7k lbs to ca from seattle. it's bye bye time
steve33444
67
02-19-2015 06:36 PM
95f2504x4
38
11-17-2011 08:39 PM
vancouver island
11-21-2009 12:30 AM
gloorm
05-30-2009 03:23 PM
Roger1
1999 to 2016 Super Duty
06-20-2007 04:05 PM
Quick Reply: Diesel Swap, beta phase questions
