Time for new Batteries x 2
I just had to have them replaced as I couldn't keep a charge on them. In doing an egr test at my service shop, I needed 11.7 volts and they wouldn't even allow for that test. Showing 11.5 volts. WTH?
I tested my factory alternator at the alt terminal and it tested at 14.2 volts so the 110 amp alternator is working. I just don't think it can handle keeping two group 27 batteries fully charged. Headed for a new 140 amp unit.
alternator swap
HI Millers...don't know about 2006'S but My 2003 allows the replacement of the 110 amp amp unit with the 135 amp alt which is the upper mounted alt on the dual alt trucks..direct bolt in.. I installed New Bosch.(about $165.from Amazon) lifetime warranty with no mileage restrictions...cheaper than a lot of rebuilts...good luck,Dave
Done periodically this would increase service life. This should also be done with new batteries prior to installation. Usually takes several hours to top off.
Sears platinum are Oddessey batteries rebranded, top of the line, imo. Also check out DC Power for alternators and upgraded power and ground cables. I went for the 275 amp (I think) on old truck. Made instant difference. Lights brighter, started easier, and idled better. Stock hot idle is like 60 amps, your headlights eat that much.
I have owned my 1999 Super Duty 7.3 liter since new. Batteries do not last longer than 3 years. I have tried Interstate, Motorcraft and others. At 3 years almost to the month, no start. New batteries equals start. I usually get credit for the remaining "life" of the 60 or 72 month batteries I take in as core exchange. Replacement of the batteries at 36 months has become a fact of ownership.
Weird, zero problems on three sets I've had, post alternator upgrade. If it was a 7.3 or 6.0 just because the alternator tested good doesn't mean it was adequate to recharge battery during use. those diesels use an incredible amount of energy during start up and for about 10 minutes after during cold weather. If user starts up,drives five miles, shuts down the batteries didn't recover. Repeat daily and in a couple months you've killed them
on
One battery had gone bad with a bad cell, which caused high current draw which evidently weakened the second battery. I replaced the first battery and the second battery only lasted a couple months, but in the process the starter crapped out.
-edit- I should add that this was back in 1987 so the truck was still pretty young and only had about 30k miles on it.
