old blue's 1956 f100, 04 crown vic power train and suspension
Old 02-16-2015, 09:03 AM
old_blue1's Avatar
old_blue1
old_blue1 is offline
Kid took truck mudbogging. Guessing water got into intake some how. It will be gone through before it is freshened up. Thanks for suggestion
  #47
Old 02-22-2015, 09:18 PM
old_blue1's Avatar
old_blue1
Picked this up for the weekend
came with TQ converter and the yoke. It is out of a 02 v6 mustang that was wrecked from the front end. I put the engine plate up to it and all the bolt holes line up perfectly and it is a two bolt starter.
The only down side is the junk yard has to drain all the fluids in there vehicles before they take them in and their way of accomplishing this is to just drill a hole in the pan. No biggie. I will try and plug weld it or add a drain plug into the pan in the same area.
I am going to buy the stock motor mounts and tranny mount and then mock up the hard mounts to these.
  #48
Old 03-16-2015, 11:14 PM
old_blue1's Avatar
old_blue1
Hoping to pick up the triangulated rear end pieces this week. They are raw materials and I plan on welding them to the crown vic rear end. I will pick up some steel stock to box the rear frame in areas where the four link will be welded to.
  #49
Old 03-17-2015, 07:50 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Show us more.
  #50
Old 04-20-2015, 12:09 AM
old_blue1's Avatar
old_blue1
Been sitting on the back burner for a little bit. Got the rear end out and hacked off the unnecessary brackets. Should be able to tack on the spring perches and get it under the truck. Be nice to be sitting on its new running gear.
  #51
Old 04-20-2015, 12:42 AM
old_blue1's Avatar
old_blue1
I forgot to mention, I am going g to leave the leaf spring rear end in for now. Due to cost and time of installation for a four link, I don't know that I could realistically get this on the road this year with everything I need to do.
  #52
Old 04-20-2015, 07:22 AM
bjmayberry2
Where did you get your spring perches?
  #53
Old 04-20-2015, 09:02 AM
old_blue1's Avatar
old_blue1
A local place called SDHQ in Mesa. A little more expensive than just getting them from summit or jegs but I got them in one day and it supports local businesses.
The following users liked this post:
  #54
Old 04-20-2015, 09:09 AM
bjmayberry2
What's the correct size? 3 1/4"?
  #55
Old 04-20-2015, 11:20 AM
old_blue1's Avatar
old_blue1
The crown Vic rear has a 3" tube
  #56
Old 04-20-2015, 06:00 PM
bjmayberry2
Thanks
  #57
Old 04-20-2015, 08:41 PM
old_blue1's Avatar
old_blue1
Or course.
  #58
Old 04-20-2015, 08:55 PM
old_blue1's Avatar
old_blue1
I sold the final piece from the crown Vic. The transmission is gone and has freed up some much needed room in the garage. I also picked up the correct plates for the rear leafs. They are about 2" wide. The smallest they had were 2.5" wide. So I have those with a 3" u-bolt. Should be able to mock these up on the rear and at least tack it into place.
  #59
Old 04-22-2015, 10:21 AM
das54's Avatar
das54
das54 is offline
Originally Posted by AXracer
Hydrolocking an engine is pretty rare, how did it happen? Was it in a boat or driven off a bridge? Best have the block magnafluxed, that much sudden pressure in the cylinder can bulge the cylinder wall, cracking it.
Can it happen when you do this with your truck?
  #60
Old 05-05-2015, 02:19 AM
old_blue1's Avatar
old_blue1
Weather is getting hot. Truck progress is slowing. So I picked this up last weekend.
2003 mach 1, 5 spd, fr500 rims, super clean black interior and completely awesome to drive
Quick Reply: old blue's 1956 f100, 04 crown vic power train and suspension
