That is a casting number that will not mean much to folks here. If you look around a little more you will find the ford part number casting beginning with a "C0TE", if indeed the engine is original to a '60 ford truck!
0H16 - That is a casting date code ~Block cast August (H) 16, 1960 (6).
C0TE would be the block casting number prefix, it's not part number related.
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
