T-18 Transmission Fluid
Everything still applies.........but with an NP435, you don't have to worry about losing the 1/4" pin.
Your trans is a bit more fiddly to get the selector forks into place in my experience, mainly reverse.
Also pushing that shifter retainer down & twisting it into place isn't easy under the dash either, but.......both jobs are character-building
Even with the trans out on the floor it's not always easy getting all three forks engaged, with an NP435. I don't remember having much problem with T18/19's.
It's just perseverance that will get it.
If it helps, you can measure the spacing between the forks (when in neutral), then check that the gears are spaced exactly the same; but reverse is still difficult to engage when you can't see in there properly.
Blurry94
11-22-2013 09:53 PM
orange peel
10-02-2003 10:32 PM
