Clunk when turning @ front end
Old 11-03-2014, 10:46 AM
quakerj's Avatar
quakerj
quakerj is offline
Something is goofy with my steering in that it makes a clunk when shifting the steering wheel from right to left. It won't do it if I'm just turning one direction, but the noise is quite pronounced when I move the wheel to the right, then immediate reverse direction to the left.
Underneath I can see the tie rod twisting, pivoting on what they're attached to, which look like ball joints or some such thing.. It seems when the tie rod pivots, the point at which it stops twisting is where it makes that loud clunk.
What is wrong here? I should also note that there is a good amount of play in the steering. From center, I can move the wheel a couple inches in either direction before the steering actually responds.
Old 11-03-2014, 07:46 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The drag link(or center link) connects to the passenger side with a tie rod end.
The drivers side tie rod connects from that link to the drivers side spindle/upright with another tie rod end.
You can move one of the wheels without the other one moving?!?!?
Or you can move the steering wheel some before the front wheels move?
If the latter, look at the slip and rag joints in the steering shaft before the steering box.
If the former, replace the tie rod ends and get an alignment before one of the wheels comes free and you have an accident.
chcknugget
17
02-04-2013 08:54 PM
snickersandapepsi
08-14-2010 04:30 PM
wanabe2
1999 to 2016 Super Duty
09-05-2009 08:03 PM
VanGo
Aerostar
09-02-2006 11:23 PM
tvvbsn
1997 - 2003 F150
01-09-2005 09:02 AM
Quick Reply: Clunk when turning @ front end
