Coolant tank getting black inside
Old 11-02-2014, 04:21 PM
tommyl's Avatar
tommyl
tommyl is offline
It appears to be exhaust. Also getting some excess pressure in tanks and it is losing coolant. Haven't found any leaks yet. "99 F350 SD
Old 11-02-2014, 06:10 PM
whitetmw's Avatar
whitetmw
whitetmw is offline
Is it Oil or Fuel? That's the first thing that has to be determined.
A leak in the High Pressure Oil System causing oil to enter the cooling system. Or, a leak in the Fuel Deliver System causing Fuel to enter the Cooling System There are several area's to consider in diagnosing the exact culprit.
Bad O-Ring Injector
Injector Cup
Head Gasket
Cylinder Wall
Failure in the HPOP/Injector Delivery System
How long has this been occurring? Does it do it all the time? Or, just under a load? Have you noticed and performance issue or anything else out of the ordinary? Any information will go a long way in helping you determine where the leak is.
Old 11-02-2014, 06:13 PM
Tugly's Avatar
Tugly
Tugly is offline
Oh crap. You're not going to like this answer.
That is usually caused by a combination of two issues: The injector cup may have a crack in it, and you have an injector not down tight enough to seal the combustion gasses from getting into the cup area - or maybe the copper washer lost it's seal. You could also have a cup that's split down the injector tip. Or... maybe the cup just lost its seal, but the cup is the only place that is a weak barrier between coolant and exhaust. Head gaskets rarely let go, but it is a very remote possibility.
It's not the end of the world, it's just a bit of work to replace injector cups. It's one of the less-expensive repairs to the truck if you use your own labor, but a shop will grab a bag of sand and bend you over.
Old 11-03-2014, 06:43 PM
tommyl's Avatar
tommyl
tommyl is offline
Ok Tugly! The problem is like this but maybe worst. Is there some sort of test(ie, with AE) to narrow the problem. Thinking CCT?
Old 11-04-2014, 02:33 AM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
There is a coolant combustion gas test kit at all auto parts stores. Around $20 if memory serves me. A handy thing to have around the shop.
97vanswap
24
05-02-2019 01:11 PM
bigalsmith102
35
12-22-2015 08:37 PM
Andy's Beast
08-19-2015 07:54 AM
aj3501
07-04-2015 05:27 PM
Kdr358
32
05-26-2013 12:43 PM
Quick Reply: Coolant tank getting black inside
