HPOP Pump leaking
on
1 Post
If it looks like it is dripping from the HPOP, then it may be coming from one of the fuel return lines the go from the front of each head to the fuel pressure regulator on the driver side of the fuel bowl. Check those two hoses. They are a common leak point. If you need to replace them you can get them here OEM / Factory
2 stroke man
23
03-12-2008 11:46 PM
