Glow plug battle
I went to Harbor Freight and bought a battery analyzer.
Digital Automotive Battery Analyzer
This instrument will give you the CCA value for your batteries.
It will help to determine when they are ready to be replaced.
As I understand, it takes 850 CCA between both batteries to crank a 7.3.
That would mean that when the batteries are at about half strength you replace them.
However I am not sure what waiting that long does to your starter.
On a side note, I have 4 batteries in my boat, one pair for each engine.
One pair got to where they would not start the engine.
Normally I would have replaced all 4, but this time I tested them and found one of each pair was 95%, the other two were bad. I kept the good ones and replaced the bad ones.
Now I check all of the batteries periodically and will replace when failing.
LA
LA
ditch witch
01-04-2009 11:42 AM
superduty4x4
18
06-02-2008 04:15 PM
