Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 11-02-2014, 01:27 PM
bigcrunch bigcrunch is offline
bigcrunch is starting off with a positive reputation.
V10 ignition coils
On my 2000 the spring leads do not snap in on the coil side like my later Tritons. Is there a replacement coil avail that has that and fits the plug and mount?
Old 11-03-2014, 11:15 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Not that I am awhere of.
There really is no need for a snap on type connection.
The spring at normal design length is long enough to stay on the coil terminal and set on the plug cap.
The spring should be a good spring friction fit on the coil terminal and need to be pulled on pretty good to get it off.
If the spring end is distorted or short for some reason then replacement or stretching it a bit in the middle area is all that is needed.
When the coil boot is on the coil, the spring should come quite near the boot tip as the plug ends compressing the spring up at least an inch up inside the boot and will engage the spring quite firmly at both ends.
Good luck..
Similar Threads
Coil twigs 1961 - 1966 F-100 & Larger F-Series Trucks 7 09-12-2014 03:27 PM
TFI Coil with DSII ? BMW2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-21-2014 02:03 AM
01 expedition ignition coils cmazz811 Expedition & Navigator 6 03-26-2014 09:49 AM
ACCEL coils for the v10 shore Modular V10 (6.8l) 14 07-15-2008 03:20 PM
got a bad coil on a 1960 F100 pita 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-26-2000 09:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
