1989 460 Temperature Guage
Hey Guys,
I have a 1989 F250, with the 460bb, and my temperature gauge never reaches the "Normal" threshold...It moves up about half an inch..
I never tow or haul more than 800lbs, so I was wondering if this is normal because of the heavy duty heating sytem, or something wasnt right.
Thanks
Thanks
The thermostat is supposed to keep your coolant at 193*.
Having a "heavy duty" cooling system is not going to make a bit of difference.
If the engine never reaches operating temperature the computer is going to run in closed loop constantly.
Do you have access to a non-contact digital infrared thermometer?
If the engine is cold (in the morning) open the radiator cap and start the engine.
If the thermostat is missing or stuck open you will see the coolant flowing across the top of the radiator.
Mine was $18 and reads -58 to 1.382*F.
I see it's up to all of $22 now!!!
Just shoot the water neck (thermostat housing) when it's up to temperature.
IR thermometers are great diagnostic tools.
Dead cylinder? which exhaust port is coolest?
Can't find the draft in your house?
Kid got a fever?
Surface temp of anything, actually....
Amazon.com: Nubee® FDA Approved Temperature Gun Non-contact Infrared IR Thermometer Range -58F to 1382F w/ Laser Sight: Kitchen & Dining
Kid got a fever?
El Padrino
02-07-2014 08:14 PM
clinkfield
29
08-16-2013 03:54 AM
