90 Tach cluster into 87
Yes, you need to do 1 thing. On the back of the oil gauge on the back of the cluster, there is a resistor in the oil pressure gauge circuit. Solder in a wire to bypass this resistor. That will make it function like a gauge again. There are a few threads floating around this. I have one saved on my computer, but I'm not there at the moment.
Here is the one I was thinking of. This makes it clear as a bell!
https://www.ford-trucks.com/forums/1...tructions.html
Ok, swapped the cluster in and no tach, no oil pressure...
I should mention this is a cab and chassis truck. Not sure if that makes a difference. The cluster was working fine when I took it out of a 90 Bronco I parted out.
Ideas?
And yes, I bypassed the resistor. Just with a wire twisted on for now till I can get my soldering iron out, but that shouldn't matter.
Ideas?
Do the temp and volt gauge work? Try grounding out the oil gauge sender wire out at the engine.It should go to high. If it does, you may need to get the sender mentioned in the linked thread. If it doesn't, there may be a problem with the connections on the cluster. If it only goes half way, the twisty wire thingy didn't work.
hbkirishwarrior
10-06-2012 12:40 PM
IDIDieselJohn
16
10-04-2011 11:40 PM
Rogue_Wulff
'80-'86 FAQs (Frequently Asked Questions)
135
07-09-2010 05:23 PM
lgower
19
10-30-2005 11:42 PM
