Hello- been a long time since I put a new t stat in. My first attempt leaked bad. Looking for suggestions. Silicone on engine and housing? Silicone on gasket? Both sides? No silicone??
As above, also make sure the stat is seated in the housing (hence the glue/adhesive) Hand tighten the hold down bolts, wrench tighten evenly - don't just tighten one side first. Someone here will be able to come up with the torque specs if desired.
HIO- good tip to drill a burp hole, not many do that anymore. should he run a 180 degree unit ? i think that was stock. tried to send you a msg but your inbox is full.
PM box is cleared. Thanks... been planning to do that.
180° T-stat? No mention of a cooling issue so no change.
Originally Posted by tsuess
1977 400. The first gasket I used had the self adhesive on one side. Should I look for one without??
It came with self adhesive? Are you sure that wasn't an applied sealing ring? Was it actually sticky?.. if so that's weird... 'never encountered a t-stat gasket like that
There are gaskets made (Auto Zone) etc. That are much more that paper. Nice and stiff with a raised bead to seal. You can also double up on the paper ones.
T stat is 192. Which I believe OEM was. It did overheat a bit but it was right after I put new temp sending switch in so I believe I just had an air bubble.
The gasket had a white piece of paper that peeled off on one side and underneath it was sticky. Just on one side.
Call me old skool but I wouldn't trust that style gasket unless I supplemented the sealing surface with a schmeer of reliable RTV... "an ounce of prevention is worth a pound of cure".
