I messed up...
#61
Thanks for the info. I'll go check out the specs page...
*edit* Looks like hydroboost is DRW only.
I suppose there is only one or two wires running back to the rear differential for the locker? I'll put it on one of the upfitter switches and control it how I want (I'd want to use it above 25mph).
I really hate computers telling me what I can and cannot do.
#62
#63
If you get a new truck, everything is ran by a computer. The E-Locker stays engaged at any speed in low range, just find away to fool the truck's computer by thinking that it's in low range all of the time. Lastly, once you start modifying your new truck, kiss your warranty go bye. I know back in 2014, the E-Locker wasn't available on the DRW models.
After looking at so many, I'm not sold on the DRW right now. I'd love to have it for the brakes and extra payload/towing. But I can build a F250 with the camper package = F350 SRW, for about $1500 cheaper.
#64
The limited slip that is used on the DRW is far superior to the one that the SRW has, there's very little slip before it engages. I'm on my second 2WD DRW and all 4 rear tires dig in whenever needed.
The hydro brakes work great but they take some time to get used to, they are very touchy.
Denny
Denny
#65
Also agree that 4.30s would be a good choice for you. But don't think 3.73s would be insufficient; the 6R140 is vastly superior to previous transmissions and if you're not planning hauling 16,000 lbs up a 15% grade the 3.73s should do a fine job.
#66
#67
#68
#69
P.S. And I have had said Jeep in some crazy places!
#70
I did some checking the other day and the 250 and 350 SRW share the same brake pads, the DRW has different pads I'm guessing bigger. I'm thinking that the 13900 gwr has something to do with it.
Denny
#71
#72
The first truck I tested was a 2013 DRW. It had the hydro brakes and they were amazing. A huge difference over the new Fords with vacuum brakes. The steering was also much easier than the other 2015 Ford trucks I tested with vacuum brakes. I assume they use two different PS pumps for each system.
The DRW, although overkill for me, might be worth the extra bit of change...
#73
So the dealer says that the incentives I would be eligible for would be whatever is available at time of delivery. Not the time I order it.
With that being said, the $4k in incentives that's currently available expire on 1/5/15. Long before my truck would be delivered. I cannot order the truck not knowing what the final price would be. I was counting on that $4k. Sooo...I guess I'm gonna have to go sit down with them and come up with something concrete. If there's better incentives at time of delivery...great, but if not, I won't be out of my comfort zone...
The dealer wants the $5k down, and an order submitted before they can even give me a price other than an 'estimate'
Oh, and they also knew I was eligible for the X-plan before I even mentioned it. During the test drive, my place of employment came up in conversation, and when we got back to the building, I guess he mentioned it to the sales manager. So I guess that's the price I'd be getting
#74
#75
