Brake Calipers Question
I did a search and didn't find much. Quick question...I have a sticking driver's side caliper. Would you guys recommend a replace or a rebuild? I know rebuild kits are very cheap, but the calipers aren't bad either.
Also, are any of you experienced with the self bleeder systems? What did you guys do that have done this procedure? I'll go today/tomorrow and either get new calipers or get the rebuild kit. Just not sure which one yet.
Well this is where my ignorance comes in. Hoses look good and not rotted or hard. What are the slides? The drivers side is getting hot enough to smell like burning asbestos and it happened immediately after changing the pads. The were working just fine before the change $&@!?$!! Is thee a way to check hoses?
The slides are what the calliper rides on. They allow the calliper to move left to right. If they are seized you will burn through one side faster than the other. If you just had them apart and didn't notice anything then I doubt that is it. I pull them apart and lube them up with never seize when I do the brakes. I don't know how you would check the lines. It's probably just good practice to replace them being that they are pretty old.
Thanks Nick. I didn't notice anything when I moved the pistons back to put the new pads in. they seemed to move freely with a little bit of resistance. I think that is normal considering you are pushing against the fluid in the line, correct? I could change the lines too I guess. I don't think its a big deal, but mine seem to be in pretty good shape. This truck has never seen a harsh winter or summer, but yeah, they are probably as old as the truck.
As much of a diy guy I am I have alyays just done reman calipers.they usually blast clean and rebuild cheap enough that if one piston were bad the kits not a great deal.and if the pistons are phenolic...they are junk no matter what. For what its worth the bosses go bad just from age as much as anything. I replaced mine when I first got mine and went completely through the brakes.peace of mind for me..
This definitely helps! Makes my decision that much easier for me. Thanks!
