Dana 60 swap
Dana 60 swap
I am buying a 97 f-250 4×4 5 speed next week that was slightly wreaked. The front axle is bent and since I hate ttb axles anyways I figured I would throw a d60 under. I have never done this swap but I hear I is pretty simple. My biggest question. Are the leaf springs different? Are the drive shafts different? Are there any tricks that make this swap easier? Any other tips or suggestions greatly appreciated
The leaf springs are different load ratings I believe but will bolt up the drive shafts are different. My f250 shaft bolted in but it's not ideal since it doesn't have the double Cardon joint in it. I'm in the process of getting a flange for the t case and a 1350 yoke for the d60 so I can use a super duty shaft
What ark redneck said about the yoke and drive shaft.
Swap over the F350 pitman arm otherwise your U turn ability will be reduced.
Leaf springs are different, the F250 springs are stiffer due to the TTB. Replace them with the F350 springs. Replace your spring and pivot bushings now while it is easy.
Prep work items like longer brake lines, sourcing your replacement (if needed) F350 tie rods, collecting needed hardware for the track bar bracket, new U bolts, and servicing of the D60 hubs are all good time savers before swap day.
There are a number of pictures in the thread in my signature file that may be of some use.
Good luck!
Good luck!
Last edited by tjc transport; 11-02-2014 at 07:12 AM. Reason: correcting a typo.. Tom
Received 3,102 Likes
on
Good luck!
Good luck!
use the complete F-350 steering components. they are different from the TTB stuff used on the F-250.
Since I am not having any luck finding a d60 for a reasonable price I am thinking of rebuilding the d50 for now. The left portion of the axle is bent and needs replaced. I found an axle housing that contains the difference cover. I have never rebuilt one of these before, is it pretty straight forward bolt together setup. It seems like the last time I took one out (about 4 years ago) there was something that was confusing, or different to work one. Any good tips for replacing the driver side of the d50
Thanks for keeping things clear!
NC_Travis
03-02-2017 08:18 AM
elroy6468
09-15-2015 10:11 PM
dougbrown
37
02-07-2011 09:33 PM
jimlj
09-20-2006 10:21 PM
