Lend an ear for my 7.3 idle sounds vid
All the talk the last few months has me wondering if I should climb under my valve covers for the 1st time since owning.
Can any of you hear loose injectors??
click on picture for video
I may be better off knot knowing. LOL
Sorry I forgot the lighter for sound refence, too windy anyway probably.
I can hear what sounds like normal #8 cackle - but it's hard to say for sure if it's anything beyond that. Air in fuel can cause cackle (hutch mod), and loose injectors are real easy to square away on a warm engine - it's just awkward to get in there the first time.
Can you get a vid from left to front to right (or the like)?
Your truck sounds normal to me - from that angle. I was just trying to be thorough, and wanted to hear what it sounded like around the front with the hood down.
This is what a couple of really loose injectors sounds like:
I drove 1500 miles like that - and got 18.5 MPG. These engines are tough.
With my video - they did not. Loose injectors are like Bam-Bam on steroids.
A knock that goes away with warming up, eh? Hutch mod? I see you have the FRx, but that's not a replacement for the Hutch. Air in oil is a fun one as our trucks age. Does the dip stick show a lot of bubbles after your normal drive?
I haven't done the hutch mod, It's next on the list, went to start on it last week and couldn't find the angle I was planning on using for the bracket for my rancor filter, then got side-tracked, I need to get the stuff for in the tank too.
Haven't checked the oil after a drive, usually do it before I start up. I'll check that tomorrow...or today, whenever head to work again.
<object width="420" height="315"><param name="movie" value="//www.youtube.com/v/s1NOxlLUqUM?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/s1NOxlLUqUM?version=3&hl=en_US" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
<object width="420" height="315"><param name="movie" value="//www.youtube.com/v/rHOv6gTZXMA?hl=en_US&version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/rHOv6gTZXMA?hl=en_US&version=3" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
I hear the clicking. From the recording through your camera, it sounds more like a push rod... but YouTube sounds can be deceiving. Is there a metallic "tink"? Here's a little trick you can try (carefully): Block the microphone(s) with something (I used my fingers), then place the camera directly on the valve cover. This makes your camera a recording mechanic's stethoscope. Here's a test I did during a buzz:
