Need to look at the plow. Used it in the morning and last night it wouldn't pivot back to the left. Not sure if ice in the line of the pressure or return line. Tried to push against my dads tractor but would only move a little after repeated bumps
Good morning Shawn. I'm hoping this snow doesn't mean we won't see another storm until mid January. Been better to get this three week later. Tractor and blower handle it OK?
No problem with the blower - the welds are holding up fine! Thanks again.
Originally Posted by ToMang07
Yup. Cheaper too. Personally I like a good balance of tire/wheel, but personally I'd rather have more sidewall and less wheel. If nothing else, up here you need it because of how bad the roads are. I know SOOO many people that have damaged/cracked wheels on low-profile tires.
After my truck is paid off I plan to run a set of steel 33" Studded Duratracs for winter/plowing. Not that I NEED them....the 35's work great. But better is well....better!
Better is always better. But the 20" are great for towing heavy, or at least that's my experience. Less sidewall flex means less sway with the big rig hooked up. That plus the new Bilsteins I put on and it tows like a champ. But I agree that for all other purposes more sidwall is more better!
Originally Posted by wildstang
I hate low profile on trucks. Look like wagon wheels. I agree need sidewalls on those. I use what I can find on Craig's list.
See above! Been watching Craigslist but no joy on CHEAP but if you want to spend $1,200 there's something out there for you.
Better be careful bumping it - good way to burst a hydraulic hose if you bump too hard. Then you'll have a mess.
That's not good. But better now while it's reasonably warm, and not in Jan/Feb when you REALLY need it.
Found the problem with the plow. The control block had water in it that froze and was stopping the lever from being pushed down to work the piston to rotate the plow to the left. Popped the ice out and works great. Happens sometimes.
Not the best picture but the control block is to the right of the hoses. The cover is off it
