52 Ford f-6 - Ford Truck Enthusiasts Forums
52 Ford f-6
Old 10-31-2014, 11:51 PM
farmette farmette is offline
farmette is starting off with a positive reputation.
52 Ford f-6
Hi. I have a 52 F-6 with a 337 industrial flathead Ford, mid engine with a Chev turbo 350 and a dana 60 locker. I do drag race this vehicle. Last time Fontana Ca. July 2014, at the Antique Nationals. The issue I am experiencing is no front brakes. Chev hubs and no drums etc. What can I do to stop the front wheels without putting on a juice brake front end. I can't go around the water box , so I have some issues getting a good launch. ? Trans brake? Thanks Marty
Old 11-01-2014, 03:07 AM
Cordless Cordless is offline
Cordless is starting off with a positive reputation.
Drag chute?
Old 11-01-2014, 08:15 AM
burnout
Thanks for your response. My issue is not stopping, but how to clean my tires after using the water box prior to staging. I do not have front brakes and cannot due a proper burnout and subsequently have a slow launch. I was thinking trans brake. Thanks Marty
Old 11-01-2014, 12:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I'm sure we'd all like to see some pics of your truck! I am curious why you are using a heavy F-6 for drag racing? Is it cut down to F1 size? What kind of times are you getting?
A trans brake won't help, it will not affect the front wheels. I can't think of anything that will work except for front brakes. If you've adapted Chev hubs to the spindles, shouldn't be that hard to adapt some GM disc brakes (Not a bad idea in any case).
Old 11-01-2014, 12:52 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
337 flathead: 1948/51 F7/F8 & 1949/51 Lincoln/Cosmopolitan.
Old 11-02-2014, 02:37 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Any other 534 owners? Dr4J 401, 477, & 534 SD Engines 100 02-23-2016 04:02 PM
New Member from Calgary, Alberta Planetmail New Member Introductions 2 01-04-2016 12:15 PM
WTB 40's Early 50's COE Cab and Front end Hughmullersa WTB - Parts & other 0 03-20-2015 08:18 AM
Hard to find Dana 60! roshan 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 09-03-2013 10:28 AM
1950 - 52 F1 Trck Build with Jag suspension and BB 460 labgraphics 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-28-2012 05:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
