1990 f150 sleeper, motor build - Ford Truck Enthusiasts Forums
Old 10-31-2014, 09:49 PM
CaptainJack_7's Avatar
CaptainJack_7 CaptainJack_7 is offline
CaptainJack_7 is starting off with a positive reputation.
My old 90 f150 4x4 5spd had a 5.0 efi motor that could not hold oil pressure. Instead of just replacing or rebuilding the motor i have decided to build a new one entirely. What I have so far is a 90 mustang factory roller block and 94 cobra r gt-40 heads with crane 1-7 roller rockers and beehive springs. I'm boring it .30 and putting new cam bearings in. It is also getting a full forged rotating assembly by SCAT and speed pro 10.18-1 compression pistons (forged of course) I also plan to install a girdle. The cam is going to be a ford racing e303 with ford racing hydraulic roller lifters. I'm getting rid of the efi system and going to a carb setup with a holley 750 double pumper and endelbrock victor intake manifold with MSD distributor and box. I also plan to run only long tubes with turn downs and possibly a 100 hit of surf juice. Any comments or suggestions?
Old 10-31-2014, 10:10 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Seriously consider a different cam...the alphabet line is way out of date and worthless in a truck. Sorry to see you are downgrading to a carb.
Since you are building the bottom end consider a 331 or 347 stroker.....
Old 10-31-2014, 10:52 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is offline
Shadow944795 is starting off with a positive reputation.
Heck if he wants to run a carb that's his choice, shame though a perfect sleeper would have a maf setup but I guess for some folks its just much easier to cut out the fuel injection and rig up a simple carb that does what it should and that's run good than playing around knee deep in wires and different parts.
Honestly though OP if you wanted to make it to the point where someone opens the hood and sees a clean stock truck a tuneable maf setup would be the way to go. Plus you get all the benfits of not having to fight it to get it to start when its cold, it adjusts on its own for differences like air temp elavation and you don't have to open the hood and readjust a few screws to try and get it to make a pass just right.
Old 11-01-2014, 12:51 AM
Thanks for the input! I'm going carb because I want to make some serious hp numbers and if I wanted to do that with efi it would cost a lot more the way I priced it. I grew up around the dirt track so I'm no stranger to carbs and tinkering with them. I would just rather tune my motor with a screwdriver rather than a computer. I know i'm probably going to start a fire storm by saying that. It is true though an efi motor will make more power than a carb at normal RPM but at wide open a properly tune holley 750 double pumper with mechanical secondaries will produce more peak power if you have the motor to back it up. And yes I am going to go with a all forged 331 kit. Any good cam recommendations? The other reason for the carb is I love the sound!!! I'm shooting for 400hp before the smurf juice.
Old 11-01-2014, 09:42 AM
rla2005's Avatar
Call Comp Cams, give them the specs. of your motor and your goal for HP/TQ. They can recommend a grind for you.
Or go with a custom cam. Too bad Camshaft Innovations closed their doors a few years ago. Cam Master Jay was a wizard
1994 F350 crew, shortened frame, w a 93 Cummins, NV4500, gear vendors and NP205 JacoFordCummins Engine Swaps 40 02-21-2017 11:18 AM
95 f150 5.0 with 1.7 rollers? does it have forged pistons? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 6 07-14-2015 10:43 PM
Stroker Time!!!! CaptainJack_7 1987 - 1996 F150 & Larger F-Series Trucks 30 05-17-2015 03:21 PM
mild 302 build expectations CaptainJack_7 1987 - 1996 F150 & Larger F-Series Trucks 2 03-04-2015 07:05 PM
Kennbelle Supercharger for 460efi Deerediesel Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 55 12-04-2012 10:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
