Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Sign in using an external account
Register Forgot Password?
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-31-2014, 09:27 PM
hillbillyk hillbillyk is offline
hillbillyk is starting off with a positive reputation.
need to find rear axle ratio, 1976 f700
I have a 76 f700 with a 3208 cat I'm using as a donor truck for a 77 f600 crewcab. I'm trying to find the rear axle ratio and see if I can use it or should change the gear ratios. vin is K70BVA85722, wb 212, color 3x, type K707, body 4A8, trans 6, axle F0N, dso 16, gvwr 27500. thanks for any help
Old 11-01-2014, 12:02 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by hillbillyk View Post
I have a 76 F700 with a 3208 cat I'm using as a donor truck for a 77 F600 crewcab. I'm trying to find the rear axle ratio and see if I can use it or should change the gear ratios.
K70BVA85722 / WB: 212 / COLOR: 3X / TYPE/GVW: K707 / BODY: 4A8 / TRANS: 6 / AXLE: F0N / MAX GVWR LBS: 27500 / DSO: 16
K70 = F700 Diesel.
B = Caterpillar model V190-3208 636 cid V8 Diesel.
V = Kentucky Truck Assembly Plant.
A85722 = 1976 Numerical Sequence of Assembly, the trucks specific serial number.
212" Wheelbase.
3X: 3 = Tan / X = Tan.
K707 = F700 Diesel, 27,500 lbs. GVWR
4A8: 4A = Black Heavy Duty Vinyl-Full Width Seat / 8 = 81A Standard Cab.
6 = Clark model 390V 5 Speed Direct.
F0N: F0 = There is no rear axle code of F0 or FO .. it could be FC or FG or FQ or? / N = Ford 9,000 lb. Capacity Front Axle with Power Steering.
27,500 lbs. Gross Vehicle Weight Rating.
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 11-03-2014, 08:11 PM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
Go to that rear axle and post up all the numbers from any data plate or stenciled numbers from the center casting.
__________________
GM=Got Mechanic?
77 F-150 4X4 400/4sp
80 Bronc 300/4sp
89 F-450 7.3/5sp rollback
94 F-700 5.9/6spd (camper/hauler project)
Old 11-06-2014, 11:30 PM
Mike Hohnstein's Avatar
Mike Hohnstein Mike Hohnstein is offline
Mike Hohnstein is starting off with a positive reputation.
Any open rear axle ratio can easily be determined by elevating one wheel, mark d/shaft pinion so rotations can be counted, turn the wheel TWO revolutions exactly, count the d/shaft turns. Helps to have two people. Example; two turns of wheel, little more than 4 1/2 turns of d/shaft = 4.56.
Similar Threads
Axle ratio... Davidvc1964 6.4L Power Stroke Diesel 7 05-22-2013 11:20 AM
gear ratio? Shanemh 1987 - 1996 F150 & Larger F-Series Trucks 2 02-25-2012 07:56 PM
94 F-700 info needed 80broncoman Large Truck 4 07-24-2010 10:30 PM
How can I find axle ratio on '02 EX harris2108 Modular V10 (6.8l) 11 11-26-2006 10:20 AM
Axle ratio? BigMick_97_Expy Expedition & Navigator 3 01-09-2002 01:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
