Info for bracing Steering box/frame
I went through the entire front end and steering system, king pins, bushings, tie rods (Moog), steering box (redhead), rebuilt column, new rag joint, etc. Now I have some movement at the frame when wheel first turns. That translates to free play from three minutes before to three minutes after the hour on the wheel. It makes it a bear to control.
I want to eliminate that and would like to get photos of how other members have solved this problem. Thanks. k
Thanks for the photos. They really help. I'm set up oem, just welded the cracks up when I had the engine out, but it's not good enough. Your work has pointed me in the right direction. In fact, I believe there is only two tubes that go through my frame.
I'll have to tackle that project, pull the box, and really look into fixing it once and for all. I love how you have your tie rods routed too. k
F-250 restorer
18
05-31-2022 01:31 PM
gman97005
06-05-2016 06:04 AM
co425
19
09-22-2014 02:09 PM
cactusbronco
01-05-2012 11:54 AM
