347 stroker info
Those blocks are supposedly only reliable up to about 400 horse. That's a pretty fair budget. You will overpower the Ranger rear suspension quite easily even without a blower. You planning on a rework there also?
In addition to the roller question, compare the main caps. Go with the bigger ones if they are different. Go with the least amount of overbore also.
The truck can handle the hp. It's got a 9 inch in with coils and custom 4 link. I have never built a 5.0l though. I know the blocks need some help to handle the power. I've heard of mustang guys running 500 on stock blocks. But I don't have much info on what's the best block to start with and so on.
on
Yes you can get 500hp from a 302 block but it's a ticking time bomb looking for a place to go off... boost causes the block to warp and eventually split and there is no way to know if it'll run for a few thousand miles or blow up the first time you wind it up. Do you really have $10k to just throw away on some fun?
If you want a reliable motor either start with a 351 block or buy an aftermarket 302 block.
Ding!
If willing to throw 8-9k at something an extra 1500 or so for a block is a mute point, right? If staying 8.2" is the goal then throw an 8.2" Dart block at it, bore it 4.155", and use that 3.400" crank and 5.400" rod and you'll have yourself a nice little 372" deal...
I have had my 347 in a mustang , 68 block , on nitrous for over 10 years.
Use the older flat rapper block and you will have no problems.
Block splitting with the roller 5.0 is common place above 500 hp.
The blocks are thin to make them lighter .
As you said in the beginning , you need good heads.
rockher_man
08-29-2020 09:55 PM
Busted Bones
01-18-2017 10:57 PM
