347 stroker info
Old 10-30-2014, 11:50 PM
xtraparts's Avatar
xtraparts
xtraparts is offline
347 stroker info
Hey guys I want to build a relatively budget 347 stroker and put a charger or twin turbos on it. I think I have mid 90s 5.0l and an older 70s 302. What would be a good block to start with? I can't build a motor with out good heads. Has anyone built one?
Old 10-31-2014, 12:01 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
Change "relatively" to "unlimited" and you are in business.
There is nothing budget oriented to a supercharged or twin turbo'd 347 stroker SBF.
Sorry, imo, make it a 331 with a medium cam and enjoy the compromise for many 10s of thousands of miles.
Is your '90s block a roller?
Old 10-31-2014, 12:16 AM
xtraparts's Avatar
xtraparts
I'm thinking I can get the parts together and machine work done for. Around 8 9 grand which is relatively cheap. For the hp. I'm sticking it in a Ford Ranger. Lol
Old 10-31-2014, 12:24 AM
85e150's Avatar
85e150
Those blocks are supposedly only reliable up to about 400 horse. That's a pretty fair budget. You will overpower the Ranger rear suspension quite easily even without a blower. You planning on a rework there also?
In addition to the roller question, compare the main caps. Go with the bigger ones if they are different. Go with the least amount of overbore also.
Old 10-31-2014, 12:31 AM
xtraparts's Avatar
xtraparts
The truck can handle the hp. It's got a 9 inch in with coils and custom 4 link. I have never built a 5.0l though. I know the blocks need some help to handle the power. I've heard of mustang guys running 500 on stock blocks. But I don't have much info on what's the best block to start with and so on.
Old 10-31-2014, 09:21 AM
Conanski's Avatar
Conanski
Conanski is offline
Yes you can get 500hp from a 302 block but it's a ticking time bomb looking for a place to go off... boost causes the block to warp and eventually split and there is no way to know if it'll run for a few thousand miles or blow up the first time you wind it up. Do you really have $10k to just throw away on some fun?
If you want a reliable motor either start with a 351 block or buy an aftermarket 302 block.
Old 11-01-2014, 04:13 PM
Motorhead351's Avatar
Motorhead351
Motorhead351 is offline
X2 except id still want 351+ cubes if going aftermarket block
Old 11-05-2014, 07:55 PM
Vibrant93's Avatar
Vibrant93
Vibrant93 is offline
Ding!
If willing to throw 8-9k at something an extra 1500 or so for a block is a mute point, right? If staying 8.2" is the goal then throw an 8.2" Dart block at it, bore it 4.155", and use that 3.400" crank and 5.400" rod and you'll have yourself a nice little 372" deal...
Old 11-05-2014, 10:12 PM
ashleyroachclip's Avatar
ashleyroachclip
ashleyroachclip is offline
I have had my 347 in a mustang , 68 block , on nitrous for over 10 years.
Use the older flat rapper block and you will have no problems.
Block splitting with the roller 5.0 is common place above 500 hp.
The blocks are thin to make them lighter .
As you said in the beginning , you need good heads.
rockher_man
08-29-2020 09:55 PM
KAGAN21
10-14-2017 02:17 PM
Busted Bones
01-18-2017 10:57 PM
Benningtonr
01-05-2016 09:33 AM
Quick Reply: 347 stroker info
