Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.7L Power Stroke Diesel 2011-2015 Ford Powerstroke 6.7 L turbo diesel engine
2015 f250 rear blocks
Old 10-30-2014, 09:43 AM
ghoyt87 ghoyt87 is offline
ghoyt87 is starting off with a positive reputation.
I've done a ton of searches and everyone talks about the 250 rear blocks being 2 inches. I got under my truck the other night and my factory blocks measured to just shy of 4 inches. It seems like everyone says that those blocks only come with the 350s...
is there some sort of package that I might have to come factory with the larger rear blocks?
Thanks
Greg
Old 10-30-2014, 09:52 AM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Ford changed the blocks size with the f250 to f350 sized blocks due to the many complaints of rear sag with the original f250 blocks
__________________
--Brett--
2011 F250 KR 6.7--6,000k heads/fogs/led switchbacks, black headlights, Recon, H&S mm, Flo pro with 6" powder-coated tip, Fusion front & rear bumpers, 20x10 Fuel Kranks, 295/65r20 Nitto trail Grapps, Denali sled deck, Compustar alarm/remote, some plasti dipping, Rigid LEDs--2013 Escape Titanium Ecoboost--2010 F150
Old 10-30-2014, 10:01 AM
Quote:
thanks, I was starting to think I was crazy...
was this change for 2015 or prior to that?
Old 10-30-2014, 10:07 AM
2ndStroke's Avatar
I believe it was around 14... Not 100% sure though
__________________
--Brett--
Old 10-30-2014, 03:46 PM
smoky_diesel's Avatar
smoky_diesel smoky_diesel is offline
smoky_diesel has a great reputation on FTE.smoky_diesel has a great reputation on FTE.smoky_diesel has a great reputation on FTE.smoky_diesel has a great reputation on FTE.smoky_diesel has a great reputation on FTE.
250s with 4" block have been discussed many times without any proof. Your the first one I have seen actually confirm it. My '14 had 1-7/8" blocks.
__________________
Justin
2014 F-250 Lariat CCLB 6.7 - Kodiak Brown, 3.55e, Amp steps, 2" lift with custom air bag setup, 295/65-20 Toyo MTs on 20x9 BMF Novakane's. 10" sub, amp. 8250 lbs
Payload: Lance 815 Cab-over, 23ft Baja 7.4mpi, Titan 3H slant
2004 Cobra 'Commuter' 14psi + N20 = 580 ft/lbs at the wheels
2009 Yamaha Raider - 113 ci, 96whp/117wtq
Old 10-30-2014, 04:06 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
See the TSB
__________________
Scott-2013 F350 with a lot of tires.
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400; 2015 Lincoln MKC
http://www.ford-trucks.com/guidelines.html
Previous Truck 2008 F250 6.4 with lots of upgrades and a suspension upgrade from Torklift International StableLoads
Old 10-30-2014, 09:55 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
If they are installing f350 blocks why not call it a f350? That and the sticker in the door jam is the only difference between them.
Old 11-01-2014, 08:23 AM
Karl4Cat's Avatar
Karl4Cat Karl4Cat is offline
Karl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to beholdKarl4Cat is a splendid one to behold
Quote:
Well, that and the one upper overload spring. Unless of course you have a 2015 with the camper package which gives the 250 the 350's upper overload spring. Then, yes, the sticker is the only difference. We've discussed this before. My theory was and is, it's strictly for marketing to the uninformed. You have to offer both to those who don't know there is no difference. Makes sure they keep both markets satisfied.
__________________
Rodney
2012 F350 4X4 6.7 SC SB SRW 3.55's with e-locker
2015 XLR Thunderbolt 395AMP
Old 11-01-2014, 10:23 AM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by senix View Post
See the TSB
Would this be covered by the 3 yr 36000 mile warranty...or the powertrain...or the body...?
Too bad I installed air bags to fix this issue already.
Old 11-01-2014, 10:28 AM
Karl4Cat's Avatar
No, it's not a recall and not paid for by Ford. It's done at the customer's request and expense. I did my own on my 09 F250. About $100 in parts...
__________________
Rodney
Old 11-01-2014, 10:29 AM
sdetweil's Avatar
sdetweil sdetweil is online now
sdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant futuresdetweil has a brilliant future
cause there are ugly vehicle registration laws using model as a key to weight for commercial vehicle.. >10,000lb GVWR triggers a bunch of requirements..
the manufacturers would call it all one model if they could..costs them profit to handle multiple almost identical models.
__________________
Sam
1955 F100 460/c6, 3.55ls - 436 hp, 489 tq
2012 F350 4x4, DRW, 3.73ls, CC, LB, 400 hp, 800 tq
2013 Keystone Alpine 3720FB 5th wheel. 40', 15,500gvwr
Old 11-01-2014, 01:57 PM
Quote:
The more I think about it, the less I want to make the change. I already have air bags. The back end is already hard enough to get in as it is.
Old 11-01-2014, 09:25 PM
senix's Avatar
Air bags are just as good.
__________________
Old 11-04-2014, 06:59 AM
Sorry for my ignorance, but if my blocks are measuring a little under 4" is that what everyone is considering the "4 inch blocks" that are on the 350's? I'm just trying to figure out for leveling purposes when I'm looking at pics of other trucks and comparing.
Old 11-04-2014, 08:12 AM
Karl4Cat's Avatar
Quote:
That's correct. They measure a touch under 4".
__________________
Rodney
Similar Threads
4 inch rear blocks 2011 F250 F2502011 6.7L Power Stroke Diesel 6 03-28-2011 12:28 AM
Rough Country 6 inch lift question? Rear 4 or 6 inch confused?? F 250 6 liter Super Duty & Heavy Duty 1 02-06-2011 11:34 PM
Factory lift blocks? stephen.south 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-08-2010 06:14 PM
Coolant Disposal gwpowell 6.0L Power Stroke Diesel 18 03-26-2010 09:16 AM
Rear spring dilemma?? Greg/Stu 1978 - 1996 Big Bronco 2 05-26-2004 03:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
