91 F150 302 bored .30
If you did have one BAD fuel injector in the whole bunch... you would get a drastically different Ohms value in one of them. For example.. if 5 of the 6 measured 11.5 to 11.9 Ohms and the sixth one measured 4 Ohms. Well, the one measuring the 4 Ohms is the one that's fried.
You will need to Remove the Plenum to Access the Passenger side, or if you have small fingers, then best of luck, its tight.
heres a video i found on youtube,
USARLen
11-08-2004 03:24 PM
psualumnut
07-15-2002 02:26 AM
