Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
U-Joint interchange for 1953 F600
Old 02-18-2015, 06:33 PM
lkc2273's Avatar
lkc2273
lkc2273 is offline
Hello all-
I'm replacing the T98 in my f600, and wondering if I might should replace the U-joints in the driveshaft while it's out and on the ground.
This brings me to the question, since I'm not finding these easy to lookup - does anyone know the equivalent parts for the three U-joints, and while we're at it, the center bearing?
Thanks!
Old 02-20-2015, 07:56 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
I'd suggest you match these locally at a good Napa or Spicer dealer. The numbers I find are old, and no doubt changed by now. The u-joints are AOT 7039-A. The carrier bearing is 8A 7025. NumberDummy probably can confirm or update hopefully. Stu
Old 02-20-2015, 09:41 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
3) B6TZ-4635-B (replaced AOT-7039-A) .. U-Joint / Obsolete ~ GREEN SALES CO. in Cincinnati OH has 21 = 800-543-4959.
Pics ~ Left: TH/F600 applications (#3) / Right: specs for B6TZ-4635-B (#3).
C3AZ-7025-B (replaced 8A-7025) .. Bearing (Spicer# 15039) / Obsolete ~ GREEN SALES CO. has 17.
Old 02-20-2015, 04:21 PM
lkc2273's Avatar
lkc2273
lkc2273 is offline
interchanges for U-Joint
Thanks to both of you.
With some looking, it seems like AOT-7039-A is still manufactured by "GKN-LOBRO" as U220, which interchanges as below:
SKF 2-0053
ACDelco 45U0103
STUDEBAKER 1687251
STUDEBAKER 674156
STUDEBAKER 682027
REO P0009
So it looks like I can get these under the AC-Delco for about $12 a piece pretty readily. Let me know if I'm mis-stating things, but thought I'd post this up as a point of information.
Thanks!
Old 02-20-2015, 04:26 PM
lkc2273's Avatar
lkc2273
lkc2273 is offline
Thanks for those details numberdummy, it looks like the FORD MOTOR COMPANY C3AZ7025B BEARING UNIT (OEM PART NUMBER: C3AZ7025B) interchanges to Timken Part Number: 207L available for about $19.
Thanks guys!
If/when I get this done, I'll post to confirm they fit...
Old 02-21-2015, 03:00 PM
NumberDummy
Originally Posted by lkc2273
Thanks for those details numberdummy, it looks like C3AZ-7025-B BEARING interchanges to Timken Part Number: 207L
C3AZ-7025-B > 207L is a BIN (Bearing Industry Number), it's not a Timken part number.
BIN's are stamped on the parts, and are what auto parts stores and bearing shops go by.
Old 02-24-2015, 04:11 PM
lkc2273's Avatar
lkc2273
lkc2273 is offline
cool, thanks! didn't know that (obviously)
RoadTractor
09-11-2019 11:51 AM
geister121
08-21-2014 03:51 PM
1972RedNeck
22
09-07-2013 04:52 PM
49willard
10-26-2012 12:42 PM
wyckedcombo17
04-20-2012 11:48 PM
Quick Reply: U-Joint interchange for 1953 F600
