please help
please help
hey i got a 2005 6.0 recently and im starting to have problems. just changed the oil with t6 and fuel filters and oil filter all oem. also new ficm. recently i have been having some problems when the truck gets up to temp. it shakes and runs awful when it gets warm to the point that i cant drive it. it will shut down and then restart after a long crank but i have to wait a few mins. this will limp me home... still running like ****. i noticed i have a few small oil spots on the driveway that were never there before the problems started. i dont have a scanner so i went to advanced auto and they told me i have p0263 p0266 p0341 p0403 p0405. those were the codes in the history. the egr and valve have been deleted so thats why its throwing that code. i think it may be an hpo leak somewhere or injector o rings but don't know for sure. ive been searching all the sites and cant find anything about the truck starting after it dies. any help of any kind would be greatly appreciated. thanks also i unplugged icp sensor and it still started and all the problems were still there. i read something on this so i dont know if that will help any.
Is the EGR valve still plugged in? Even with a delete
the PCM needs to see it for the fan to run correctly.
From the P0405 I would say that your is not and needs to be.
Start by looking at the harness I think you may have some
chaffing going on. Look for flat crushed or bare wires. Check
the harness routing. There is a writeup in the Tech Folder at
the top of the forum that will be helpful for you to read.
Sean
Sean
Sean
Sean
Sent from my Telegraph using IB AutoGroup
I was thinking the same. I'm leaning towards bad orings I'm hoping they are not just bad all together. I guess I'll have to wait. My local shop can't get it in until next week and I refuse to take it to the dealership so they can throw parts at it and waste my money. I was just looking to see if anyone had similar problems or know what my problem is so I can get a heads up on how much money I'm gonna have to spend. Thanks guys
<<<@!1!@>>>
The p0263 and p0266 are cylinder balance codes and I would be willing to bet those 2 injectors need to be replaced. I would also have your dynamic fuel pressure tested, that is the fuel pressure at WOT ( wide open throttle ) anything less than 45 PSI can damage the injectors. One test that you can do that is easy enough is the bubble test, remove the secondary fuel filter and with the filter and cap removed crank the engine over as shown in this video and watch for bubbles in the fuel filter housing,
thecaptincole
10-06-2016 05:26 PM
Gothere
03-05-2015 11:12 PM
jeffwecker
07-29-2005 10:36 AM
