66 F500 Parts?
66 F500 Parts?
Hello. Sort of new here. Had an account a few years back. Anyways, i just picked up a complete 66 F500 for $450. It has the 330 and 4 speed. It will be my daily driver after winter. One problem im having right now is i cant find ANYTHING for the 330. Ive been searching ever since i bought it a week ago but all I found was an oil pump. If anyone could point me in the right direction, id really appreciate it.
Your FT 330 is almost identical to any FE motor. A big FE would solve your problem for a lot less than a different swap.
Try here for sage advice: 332-428 Ford FE Engine Forum
Eric
Eric
Eric
Eric
There are two different 330 2V FT engines. The 330 2V Medium Duty uses the same oil pump (C8AZ-6600-A) as an FE engine, so it's EZ to find.
The 330 2V Heavy Duty uses a different oil pump (C9TZ-6600-A) that is also specific to 361 2V & 391 4V FT engines.
Which 330 2V FT engine do you have and what else do you need besides an oil pump?
btw: If you're thinking of swapping in an FE engine, be aware that they use a completely different engine mounting system than an FT.
Welcome to FTE
