Rear Drums are Binding
Obviously something is not the right part.
Does the drum slide all the way onto the axle? If not, the brake shoes may be wrong. Does the new drum hit the backing plate? What happens when you put the lug nuts on without the wheel?
Next is the rims/tires. Something must be too big & not fitting, or hitting the fender somewhere.
If the shoes are too far apart by the adjuster, you will not be able to push the drum over the shoes. If you are not sure, collapse the adjuster all the way down & try again.
Something is changing when you put the lug nuts on... either the drum is hitting something behind it or the axle is being pulled out... Or BOTH!
Inline66
09-01-2015 01:54 PM
JetBlackBronco
1978 - 1996 Big Bronco
10-22-2005 05:40 AM
luke_trash
06-30-2003 10:07 PM
