Oil drain plug and gasket ??
#31
Let's make a bet, I have to change my oil soon and I would wager than after 70k miles with a fumoto valve there is nothing interesting to drain out if I pull the valve.
Sent from my Telegraph using IB AutoGroup
#32
#33
#34
Chris, I may be asking some dumb questions, but like I said, I haven't used one before. How far up into the pan does the valve go? If it is just a couple of tenths of an inch, no big deal, but an inch or so and I would think it would leave quite a bit of used oil in the pan.
#35
on
A copper gasket would take care of that...
Does anyone have the right part number for the Fumoto valve for a '15 6.7?
I'm going to buy one.. If for no other reason than to p!$$ off xV-whatheheckever..
#36
on
what bothers me is it extends up into the oil pan, trapping the small particles and debree forever in the oil pan, so you never truely get the heavys that might be laying in the pan out. might just keep circulating them thru the oil system like micro sandpaper.
the plug gets most if not all out of the pan, u can even dump cheap quart of oil in when the plugs out to give it that little extra flush. but with the valve you cannot. as its inlet is higher then the low drainpoint of pan.
#37
#38
Fumoto F-106N Engine Oil Drain Valve
I'll under priced it a little, it's 26 on amazon.
#40
My 07 oil plug is not magnetic. Something different for my tranny pan with the big o ring magnet installed.
Funny though, in the middle of rebuilding a Yam 450f four stroke engine after one of the four, first gear dogs, broke off of the gear and found its way into jamming the cam chain.
I will put a magnetic plug back in as I think it would have saved a lot of work and a thousand bucks.
#42
#43
#44
#45
on
It makes no difference which way they go.
https://www.google.com/search?q=fumo...4GADA#imgdii=_
