Covers and your trailer
#32
Randy - After doing ours then seeing yours really emphasizes the difference between the high profile, virtually straight roof and our lower profile and roof and very rounded nose cap, The only 'kink' in ours is the ladder which skews the rear of the cover a little bit. I'll try to get a couple photos tomorrow of it at rest for the next 3-4 months after I hitch it up and push it back on its newly enlarged parking pad - 9 tons of freshly shoveled in #3 crushed stone on top of 6 tons of the earlier version of the pad and after that, might even take a day off and work on my '31 roadster.
#34
I really like (NOT!!) the ADCO instructions. They say unwad - that's my word - and then reroll inside out and drag it on the roof like a firehose then throw the forward end over the nose and it will almost install itself. Suurree - that works - only in someone elses dreams. I'm sure Randy has some good words for that as well. Dragging up on the roof is fine with a second person guiding the ~50 feet of material, but the rest, dodging a/c's, roof vents, ladders all while trying to maintain your balance on a quivering and crowned roof while following their instructions just wont work. Maybe on a flat roof, TT or MH - yeah, but not on a late model fiver with a fairly aero nose.
I know, I'm whining, but these covers are not an accessory to be taken lightly. They are fairly heavy and especially when new, somewhat unwieldy to handle. They are also somewhat fragile if you snag it as you will end up with a tear. And then as Mr Adams noted, that 12-13' potential for a fall and subsequent trip to an emergency room is not to be taken lightly.
The fall itself never hurts, but that sudden stop against the ground will
From ~13 feet, that's 29 feet per second at a velocity of almost 20 miles per hour and it only took .9/second for you to get there, including acceleration time!!!! Just enough time to think "OH S@#T"
Now, that cover - just made it on our 5er to protect it from our first 1/2" snow dusting of the year
#36
on
I watched some YouTube video thatsaid the cover was packaged in an orientation where you unroll it from front to back and then just throw it over the sides... WRONG!!!! It was set to be unrolled sideways and even at that, we found that it had to be spun around to be oriented correctly... Weighing in at a good 40-45# and being big enough to cover half a zip–code, that was not an easy task..
Plus - I couldn't do the roof so my DW got up there (brave soul that she is) ... My neigbor and I assisted with the pulling and cajoling....
What do you cover your trailer with?
#38
Randy - can I borrow your DW next year? Mine is good at guiding the cover from the ground and handing me stuff but has a 'glass' back and wont do ladders nor can she pull very hard.
Heck, I wont even do the upper part of the house back roof to clean gutters any longer either - a walk out basement puts it 3 stories up and that 5er seems to get higher every year too.
#40
on
I don't do ladders and roofs very well... Fell off the top of our two story house when I was a kid. Been screwed up in the head ever since. Mind you I can fly. Planes and even jump out of them without issue - but ladders and roofs are my downfall......
#41
I was into my 70's the last time I installed a cover.Wasn't THAT bad! Threw away the instructions after I read them!! I spread it out in front of the trailer with the back on the ground below the front of the RV. I had a pole on top with a scrub brush attached. Has DW hood the cover onto the brush and pulled the rear of the cover up the front of the RV and pulled it towards the rear while DW kept going side to side making sure the cover slid up the RV correctly. I got it all oriented on the roof then climbed down the RV ladder and did the strapping..... I had already taped bubble wrap on the sharp corners/edges etc. I just didn't do it until I had a sunny, breeze free day to do it....altho a breeze ( not over 5MPH) from rear to front did help.
#42
#43
A couple photos of our covered 5er:
The wind skewed the front of the cover when the straps loosened up - and between rain, snow, wind and #$%^ cold, I just haven't had the desire to drag the ladder out, climb up there and scoot it back to center --- and may not find that desire this year if it stays nasty.
#44
Okay, why don't all you whiners just move a few steps South. If you can learn to drawl, we would love to have you. We like to poke fun at Northerners and yes, the southern stereotypes are true. It makes for much less stress when expectations are low! We seldom get snow and what we get doesn't last but a day or two most of the time.
Steve
Steve
#45
Steve
Steve
We tried to move closer to y'all (outside of Roanoke) a couple years ago but it just wasn't to be. Heck, I've even lived in the South (Gastonia, NC and outside of Dallas, TX) but even experienced heavy SNOW and ice storms) both places. At least I live on the opposite side of NY from Buffalo. Our snow is minimal.
