What ofset and backspacing....
SS rims are OK looking I guess. For Most FORD Trucks, I think the American Racing "Outlaw" rims are awesome. They are aluminum, but with clear powdercoating, they should shine forever!
About the SS rims. I would go with a stock offset, 16"x8" with LT 265/75R-16 or P265/70R-16 tires on The front.
On the rear, you'll want about a 3 1/2" to 4 1/2" offset in a 16"x8" with the same tires as above. You'll enjoy the convenience of only having to carry one spare in case of a flat. You want a 70 to 75 series tire for the sidewall, since your rig weighs a little bit much to put on 60 series tires and you wouldn't benefit from the bump steer and the rear end kickig out on you when you go over an expansion joint on the x-way. Well, I've said too much! Good luck and post your pics when your done! Thanks....
I didn't mean to sway your decision, but chrome is such a brittle coating. If you like the look of the S/S's, maybe you would consider the Chrome wheels and Baby Moon Caps. Real Hot-Roddin' fun!!! They're about $60.00 each for 15"x8", with multiple off-sets. Check out , www.petepaulsen.com
Good luck....
Good luck....
77effie
20
03-17-2006 12:31 PM
