limp mode
limp mode
Last week I got the yellow wrench. I've never seen it before in all the Fords I've owned. Learned from the book I'm now in limp mode and my truck will soon stop working or come close. I dumped it off at the dealer next to my work. After a day they tell me it's my throttle body sensor and how it affects my power. Funny thing is I never lost any power. It ran great. They removed a large amount of money from me and off I went. Two days later it came back on. Truck runs good with no hiccups for 3 days till I give it back to them. As of now the senior tech so I'm told took it home with the laptop connected to see why the limp mode comes on but truck still runs good.
My question being unfamiliar with limp mode is if the truck is running good, what are some other causes of it. I'm ready to argue the whole throttle body and sensor replacement was uncalled for. I didn't see the codes so how do I know for sure it caused it. No difference in performance. I'll find out tomorrow.
Truck is a 2006 V-10 F350 4x4 128000 miles.
Since the same thing happened after the $$$ throttle body sensor replacement I would demand that $$$ back unless they can prove it was actually a problem.
I'm no certified technician, but from my experience I know that some codes can be generated by poor electrical connections and nothing more.
I could give you details on 4 costly repairs proposed by dealers (2 Ford, 1 Chevy, 1 Chrysler) which ALL turned out to be poor sensor connection issues.
Caveat Emptor.
Well got the truck back. The tech said he never saw it go into limp mode going home or going to work. They asked if they go for another ride and it still didn't do it. I know it was run because I had it half full and got it back nearly empty. I asked about when it came on when I dropped it off and said it didn't show any code. The only time it showed one was for the TB. So I took it back. They didn't charge me anything.
The comment about the loose connection might be something. I also have a 2009 Grand Cherokee 5.7. Same thing with the light. Parts were thrown at it. It ended up found by a tech who found a bare spot on wire. They ate the cost of the parts.
Guess I'll see what happens. Thanks for the responses.
miyang
15
06-22-2015 08:45 AM
