2014 F250 keyless entry code
Problem fixed! Sales called and asked that I bring the truck in and they would take care of it.. when we got there yesterday, he came out with a small box in his hand, it was a new after market entry key pad with a new number. So it was after market after all.. but then some other trucks on the lot had the same keypad even tho some had a different look to them.
Salesman said he needed to find someone in the tech department to put it on as he didn't know how,, my son was with me and he is technically inclined, so the salesman handed it to him and said thanks and if you have a problem, come on back down.
No charge and no computer hook up...
thanks for all the replies and help...
Crystal
Well , you may have but I have learned that when you look at the keypad, one that is factory installed is embedded into the area of the handle and lock and the one that is after market is a keypad that sticks to the door , where ever you want it, with it's own master code, not the one we have been looking for, then you have to have both keys in order to program the truck computer and this keypad together , after that you can change the code to one you want but as with the installed one, the master code never changes. To me, this is not as secure as one that is factory installed as the keypad just peels off and a new one is stuck in it's place.
thanks
thanks for looking out for me. I do have a question about the keyless entry?
My son found a number beneath the dash that he feels may be the factory code had the keyless entry been factory installed originally, but the 5-digit number has an L after it. Just curious , would this maybe have been the original master code?
thanks
Crystal,
thanks
thanks
Crystal
factory set code
2015 Owners manual......should be same for 2014
Programming a Personal Entry Code
To create your own personal entry code:
1. Enter the factory-set code.
2. Press 1·2 on the keypad within five
seconds.
3. Enter your personal 5-digit code. You
must enter each number within five
seconds of each other.
4. Press 1·2 on the keypad to save
personal code 1.
The doors will lock then unlock to confirm
that programming was successful.
To program additional personal entry
codes, repeat Steps 1-3, then for Step 4:
• press 3·4 to save personal code 2
• press 5·6 to save personal code 3
• press 7·8 to save personal code 4
• press 9·0 to save personal code 5.
You may also program a personal entry
code through the MyFord Touch system.
Tips:
• Do not set a code that uses five of the
same number.
• Do not use five numbers in sequential
order.
• The factory-set code will work even if
you have set your own personal code.
Erasing a Personal Code
1. Enter the factory-set 5-digit code.
2. Press and release 1·2 on the keypad
within five seconds.
3. Press and hold 1·2 for two seconds.
You must do this within five seconds
of completing Step 2.
All personal codes will erase and only the
factory-set 5-digit code will work.
Anti-Scan Feature
The keypad will go into an anti-scan mode
if you enter the wrong code seven times
(35 consecutive button presses). This
mode disables the keypad for one minute
and the keypad lamp will flash.
The anti-scan feature will turn off after:
• one minute of keypad inactivity
• pressing the unlock button on the
remote control
• switching the ignition on.
Unlocking and Locking the Doors
To Unlock the Driver Door
Enter the factory-set 5-digit code or your
personal code. You must press each
number within five seconds of each other.
The interior lamps will illuminate.
Note: All doors will unlock if you disable
the two-stage unlocking mode. See
Locking and Unlocking (page 56).
To Unlock All Doors
Enter the factory-set code or your personal
code, then press 3·4 within five seconds.
To Lock All Doors
Press and hold 7·8 and 9·0 at the same
time (with the driver door closed). You do
not need to enter the keypad code first.
Displaying the Factory Set Code
Note: You will need to have two
programmed passive anti-theft keys for this
procedure.
2. Switch the ignition off and remove the
key.
3. Insert the second key into the ignition
and switch the ignition on.
The factory-set code will display for a few
seconds.
Note: The code may not display until after
any other warning messages first display.
To display the factory-set code in the
information display:
1. Insert a key into the ignition and switch
the ignition on for a few seconds.
58
seconds.
personal code 1.
Tips:
same number.
order.
Anti-Scan Feature
remote control
To Unlock All Doors
To Lock All Doors
procedure.
key.
seconds.
58
How many numbers do you put in ?
