So they only made the one right?
#31
#33
My guess is that Ford needed the 5.4L for F150 and Expedition and the V10 was little to no cost upgrade. I see 5.4L Excursions for sale around me, not as common as V10 but out there. I also think in the later model years of the Excursion that V10 was part of the Eddie Bauer and Limited packages but I need to find my brochure...anyone?
#34
There's several Gas 5.4L V8 Excursions in the area here:
http://washingtondc.craigslist.org/n...737400191.html
http://washingtondc.craigslist.org/d...732262850.html
http://annapolis.craigslist.org/cto/4731489382.html
http://fredericksburg.craigslist.org...703481282.html
Apparently my Ex does not exist either...
It starts getting really spotty at the 10 year mark. After that you're lucky if it's got anything. I ran a whole bunch of the fleet vehicles at work with little problem.
#35
on
#37
#38
Well my truck also doesn't exist on that website, but on a different one I found this
<table class="results"><tbody><tr><td>Manufacturer address:</td><td class="res">American Road</td></tr> <tr><td>
</td><td class="res">Dearborn MI 48121</td></tr> <tr><td>Make:</td><td class="res">Ford</td></tr> <tr><td>Build Date</td><td class="res">25.08.2000</td></tr> <tr><td>Vehicle Line</td><td class="res">EXCURSION</td></tr> <tr><td>Body Style</td><td class="res">4 Door Wagon</td></tr> <tr><td>Version</td><td class="res">250 Series</td></tr> <tr><td>Engine</td><td class="res">5.4L Modular SOHC V8</td></tr> <tr><td>Transmission</td><td class="res">E4OD(4R100)</td></tr> <tr><td>Drive</td><td class="res">LHD RWD</td></tr> <tr><td>Axle Ratio</td><td class="res">3.73</td></tr> <tr><td>Emission</td><td class="res">With 49 State Emission Requirements</td></tr> <tr><td>Air Conditioning</td><td class="res">HD Manual Air Conditioning</td></tr> <tr><td>Paint</td><td class="res">Estate Green</td></tr> <tr><td>Check digit:</td><td class="res">9</td></tr> <tr><td>Model year:</td><td class="res">2014</td></tr> <tr><td>Plant code:</td><td class="res">United States</td></tr> <tr><td>Sequential number:</td><td class="res">A19459</td></tr> <tr><td>Minor features: </td><td class="res">Medium Parchment</td></tr><tr><td>
</td><td class="res">137"/3480MM Wheelbase</td></tr><tr><td>
</td><td class="res">Limited</td></tr><tr><td>
</td><td class="res">Less Fleet Related Items</td></tr><tr><td>
</td><td class="res">Kentucky Truck Plant Build</td></tr><tr><td>
</td><td class="res">U.S. Sales</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Convenience Group</td></tr><tr class="expanded" style=""><td>
</td><td class="res">8600 LB. GVW</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Special Value Packages</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Ambient Temp/Speed Pack</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Special Language Label</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Owner Hand Book Pack</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Electric Rear Quarter Window</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Privacy Glass</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Heated Rear Window</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Unique Full Floor Console</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Fixed Foot Pedals</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Front Floor Carpet Mats</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Rear Floor Carpet Mats</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Carpet Floor Covering</td></tr><tr class="expanded" style=""><td>
</td><td class="res">I/P Insert - Level 1</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Level 4 Door Trim Panel</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Load Retention Net</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Lighted Running Boards</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Bright Front Grille</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Integrated Roof Rack</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Lower Body Cladding</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Electrochromic R/View Mirror</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Dual Power Htd Signal Mirrors</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Temp Control Driver Seat</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Temp Control Passengers Seat</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Sec Row 60/40 (3 P)-Easy Entry</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With 3rd Row Bench Seat</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Driver 6 Way Pwr.Seat Adjuster</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Heavy Duty Trailer Towing</td></tr><tr class="expanded" style=""><td>
</td><td class="res">4 Door Wagon</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Central Locking System</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Door Entry Remote Control Unit</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Int. Rear Window Wiper/Washer</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Speed Sensitive Windscreen Wipers</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Body Tu-Tone Paint</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Front Bumper - Steel Chromed</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Rear Bumper - Steel Step - Chromed</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Front Licence Plate Bracket</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Driver Air Bag</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Passenger Air Bag</td></tr><tr class="expanded" style=""><td>
</td><td class="res">7.0 X 16" 6 Window Aluminium Wheel</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Wheel Covers</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Immersion Heater</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Front Stabilizer Bar</td></tr><tr class="expanded" style=""><td>
</td><td class="res">3.73</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Rear Axle Limited Slip Diff</td></tr><tr class="expanded" style=""><td>
</td><td class="res">5.4L Modular SOHC V8</td></tr><tr class="expanded" style=""><td>
</td><td class="res">4 Wheel Anti-Lock Braking System</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Transfer Case</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Skid Plates</td></tr><tr class="expanded" style=""><td>
</td><td class="res">For Unleaded Fuel</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Tilt Steering Wheel</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Leather Steering Wheel</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Speed Control</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With MPH/KMH Speedometer</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Tripminder Assy</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Reverse Proximity Sensor</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Heavy Duty Battery</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Heavy Duty Alternator</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Elect Prem Stro/Cass/Disc/Clock</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With NAAO Radio Frequency</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Family Entertainment System</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Rear Seat Radio Controls</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less Daytime Running Lamps</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Aero Headlamps</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Front Fog Lamps</td></tr><tr class="expanded" style=""><td>
</td><td class="res">With Dual Beam Dome Map Light</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Estate Green</td></tr><tr class="expanded" style=""><td>
</td><td class="res">250 Series</td></tr><tr class="expanded" style=""><td>
</td><td class="res">Less B&A Control Codes Issue 030388</td></tr><tr class="expanded" style=""><td>
</td><td class="res">E4OD(4R100)</td></tr><tr class="expanded" style=""><td>
</td><td class="res">EXCURSION</td></tr><tr class="expanded" style=""><td>
</td><td class="res">(+)"USA"</td></tr><tr class="expanded" style=""><td>
</td><td class="res">(-)"N"</td></tr><tr class="expanded" style=""><td>
</td><td class="res">(-)"CDN"</td></tr><tr class="expanded" style=""><td>
</td><td class="res">(-)"BRN"</td></tr></tbody></table>
#40
#41
#44
#45
I know where to "get" one, but I don't know what vehicle to get it out of. I'm basically just pulling out the yolk, unbolting the axle from the springs and then doing the opposite to mine to install right?
