90 f150 302/EAOD to 90 f150 351/EAOD Swap
Old 10-28-2014, 12:13 PM
emschris's Avatar
emschris
emschris is offline
Have a 1990 f150 302/EAOD, wanting to swap in a 90 f150/EAOD.
I have searched it a gleening some info I think I know, but I would rather just know. Most swaps I have found were switching years of engine requiring a bit more work. I am fortunate enough to have a same year same trans donor. I am most concerned regaurding the computer and harness. What from the donor do I need? Engine(obviously) the trans I have is good, so I prefer to keep it. Flywheel and or torque converter? I know about the exhaust, easy fix. I would also be interested in swaping over from SD to MAF, but I can read up on that. I just want to make sure all the componets are gonna work together to get it up and running. Once I know what will work I may consider some mods prior to install, may even freshen the whole engine with a mild build. Any info appreciated, Thanx
Edit: E4OD Trans in both trucks
Old 10-28-2014, 12:25 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
There is no EAOD transmission. It's either a mechanical/hydraulic AOD or an electronic controlled E4OD. The difficulty on the swap depends on which transmission(s) are in scope here.
Old 10-28-2014, 12:33 PM
emschris's Avatar
emschris
emschris is offline
Oops, mislabeld the trans, my bad, E4OD, same in both trucks.
Old 10-28-2014, 04:19 PM
Conanski's Avatar
Conanski
Conanski is offline
You need the 5.8 engine, the 5.8 flexplate, and the 5.8 computer. You can make the existing exhaust system fit the 5.8 but since you got the complete donor truck swap the 5.8 Y pipe over too. That is it, do not swap any wiring.
Old 10-28-2014, 05:05 PM
emschris's Avatar
emschris
emschris is offline
Sweet, just the info I was looking for.
neverenoughtools
45
11-13-2018 11:00 AM
emschris
Engine Swaps
10-28-2014 05:15 PM
mudbogger93
05-07-2012 10:12 PM
sibernut
07-15-2009 07:42 AM
92_FlareSide
08-25-2005 12:25 AM
Quick Reply: 90 f150 302/EAOD to 90 f150 351/EAOD Swap
