Summit, CPP, steering columns.....
#61
I am guessing this isn't the first this happened. Hopefully they re-designed it already.
This is the matching part along with the broken one. It's obvious to me why it failed in that spot...
#62
Received 4,108 Likes
on
#63
#64
#67
Their # 440-826-4488
#68
I was on the Flaming River site and a tech support window popped-up. I thought maybe this would be a good way to talk to them... this was disappointing.
I saved the chat:
Jerry Support Agent
Jerry Hello, can we help answer any questions you might have?
Client Hello,
I have a column that has a broken tilt lock shoe. The column was already installed when I purchased the vehicle. The part broke off and was loose inside of the column. It got caught while turning. I disassembled it and removed the parts.
You can see a picture here: http://cimg8.ibsrv.n…7491ef9227ec4d0569fd25c88f.jpg
(I believe it is about 7 yrs old. There was a marking inside with the date.)
I think the part has a weak spot in it. I assume it's no longer made that way but I thought I should tell you what happened.
Jerry Is it a Flaming River column? I can't send you the parts. You would need to send the column back here for repair. In order to do that you need a RMA number and would have to call in for it.
Client I do not believe the column is under warranty.
Jerry I’m sure it is not under warranty, and I cant tell you if the design has changed until we look at it. We don't know the part number ir even if it is a Flaming River column yet.
Jerry Is it column shift, floor shift, what is the cone style, and tube size. If this column is already apart, you are better off just getting a new one.
Client This is the inside of the column:
http://cimg0.ibsrv.n…50b23507231f6f6ae14471cad7.jpg
Client I was contacting you to inform you of what happened. It seemed like a safety issue and thought you should know.
Jerry has closed the chat.
I saved the chat:
Jerry Support Agent
Client Hello,
#69
"Client This is the inside of the column:
Jerry has closed the chat."
For the company (Flaming River) that's supposed to have the safe column to shut you out that way is not a good sign. I'm hoping IDIDIT would be more concerned about a safety issue.
#70
#71
I bet the chat guys have been instructed not to discuss safety issues. That's the keyword before he ended the chat.
#72
The links were to the pics in this thread:
http://cimg8.ibsrv.net/gimg/www.ford...69fd25c88f.jpg
http://cimg0.ibsrv.net/gimg/www.ford...e14471cad7.jpg
#74
That could be, but the whole direction of this thread is to buy from a few domestic vendors to ensure one's safety, and then one of the vendors bugs out when the word is mentioned. Seems like they only want to mention "safety" when selling the product as opposed to fixing an issue?
#75
