94 f-350 with 460 has me stumped!
#31
That is the problem i am chasing. The truck will not start. i cant warm it up and drive it if it wont start.
#32
Those IAT/ACT and ECT codes are probably invalid since you cannot start the truck. It would be advisable to check those sensors using a meter just to verify.
#33
#36
I did unplug the ECT and tried to start,no go. I will the pull the plugs again and look. will go over all vacuum lines. I will also remove the idle air control and clean that and the throttle body. What do you mean by the seat area? Thanks guys I know we can make this old girl run again!!
#37
Another thing you can try if all other things are fine is to spray around the manifold edges with wd40 while trying to start it. The way im thinking is if you have fuel in the cylinders and you have spark maybe you're sucking air through the intake gaskets or bad vacuum
line somewhere. Maybe others have other thoughts.
#39
I checked to see if the plugs were wet and they are bone dry. Checked for vac leaks couldn't find anything right off. This weekend I'm gonna pull the fuel rail and injectors and turn It over and see if they are spraying. Gotta start somewhere with getting her running
#40
#41
#44
Glad to hear you got her going! These old 460's sound beautiful... now about those pics i was asking for earlier...
#45
Word to the wise.
I am happy you got your 7.5 started up! I wanted to advise you to pickup a spare distributor, to keep in the truck, as the PIP sensors in the TFI distributors will fail and most aftermarket ones will fail quickly. I found 2 new Motorcraft sensors and replaced the one in my aftermarket distributor that had failed, and keep it behind the back seat of my crew cab. Last time it failed, I pulled the distributor and dropped in my good spare and lit it right up, and away I went. I usually keep a Ford distributor wrench, timing light, and a piece of yellow tire marker crayon in truck as well. Happy motoring! Dale
