Replaced hub bearing w/timken now issue
I have a 2001 f250 v-10 4wd with 117,000 miles. I just replaced drivers side front hub bearing assy and not sure if it's the new bearing or what but now I keep hearing this crazy noise from suspension area. It has had bangs and pops for a while now. It almost sounds like abs motor going off but louder. Does it going slow fast or whatever. Brakes on or off. Trucks ball joints were done about two months ago and new shocks, trac bar replaced this summer only thing not done was tie rod ends and all bushings. Brakes are good new rotors and pads this summer also. It's like taking two inflated balloons and rub them together real fast. It may be the timken bearing maybe bad from get go. Has anybody experienced this?
I would be pulling the caliper and rotor to check things out. If the bearing itself has a cage that came apart or failed in another way you should be able to hear and feel it while turning the unit by hand. A cage that comes apart will make bumping and dragging noises. I had that happen on an Explorer a few months ago.
A bad ABS sensor would cause the ABS to cycle but the steering wheel usually pulls to one side and does it only when braking. Since it only started doing this after the unit bearing was replaced that is obviously the place to look first. I am assuming you assembled everything properly when the unit bearing was replaced.
I havent pulled it apart yet. I got called into work today so ill look at it tonight. It may be coming from passenger side not sure hard to tell while sitting in truck driving and my window down sounds from left wheel but window up sounds almost like passenger side. Im not sure cause its not a constant sound. It comes and goes real quick hard to pinpoint. It seems to be more previlant from 40mph and slower doesnt do it on freeway at 75 mph
Well I found the issue it wasnt the new timken bearing it was the pos cheap bearing on the passenger side. I pulled it today and the needle bearing that the axle shaft spins on when in 4wd was locked tighter than a drum. The noise was it trying to lock on the shaft and when it couldnt turn it it would squeek real loud. I went and put a new timken on that side and all is good now. I guess I learned my lesson trying to get away with those cheap china junk. Only lasted 3 months both sides. O well live and learn I guess. Not sure If i was supposed to do this but I greased that bearing in the new ones so they dont run dry. I hope I didnt jack it up doing that. Thanks guys for the help
Most go right to the wheel bearing first but really need to pull apart regularly to keep from seizing.
