TEN YEARS LATER!!
I've done a lot of reading on the V10, and this truck has 4.30 gears. I'm used to the diesel so I don't expect equal pulling power, but do you think I'll be okay? I have a Weekend Warrior 34ft 3 axle bumper pull with a Sandrail and all the goodies. Tthe trailer is 12K minimum when loaded. I'm worried about I-10W through Palm Springs with the head winds out there and other than that a couple of mild hills. Tyically towing between Long Beach, CA and Glamis. Anybody familiar with that route?
As long as you don't expect them to pull exactly the same then you will be very pleased with the v10. Diesels are made to pull below 3,000 rpm and have a narrow power band and gassers are made to make power over a wider power band(2,500-5,000 rpm). Expect to pull hills a gear or two lower and 500-1,000 rpms higher, but that isn't a bad thing, just different. Don't be afraid of the rpms that aren't on your diesel tach either. 4,500 rpm up a 10 mile hill will not cause your truck to shoot spark plugs through the hood, send engine parts flying all over the road, cause your truck to blow up, etc.
You WILL need increased transmission cooling in hot weather, most recommend upgrading to the cooler off of a 6.0L truck.
Tom, I usually hit that pilot on my way from our Springfield, Massachusetts terminal when I am heading over to Buffalo.
Sean, that 55 mph California speed limit drives me crazy. I usually go into the state on 10 or 40 and have to go up to Sacramento and then come back out the same way. Makes for a long drive at that speed.
We just have to be patient here when pulling.
That route the OP refers too is a pretty simple and flat route. If he continued east on the 10 beyond Indio up to Desert Center, that would be a little different climbing that grade.
What that normally means is that most trailers travel around 60-62 mph instead of in the 70's.
Edit-i usually stop at the loves there in Coachella or the pilot in palm springs, make my delivery in Anaheim and then head to Sacramento to pick up my next load. I love the views out there, I just wish I could run a little faster
When I am towing my personal equipment I don't go over 60 mph regardless of what the speed limit is. I drive a tractor and trailer for a living(limited to 65) and running 11 hours a day at 10 mph slower takes money out of my pocket. Most states look the other way when the truck speed limit is slower than the car limit, but California is not one of them lol.
When we go east, we usually stop at the Pilot east of Quartzite about 35 miles, off of Gold Nugget Road. You don't have to pay the highest federal fuel tax in the country, unless you wait until CA. NY is second and no need to get anywhere close!
It's a local SoCal truck since new, bought from original owner. Good maintenance and it's as clean as it looks in the pic-84Kmiles. For the looks department I'd like to add 18 inch wheels, leveling kit, BFG's and some kind of boards. For power I'm thinking of a Y-pipe, cat back, and an SCT tuner. Don't know much about it, just what I've read on here. I think I got a fair deal, about 2,800 under book.
#30
