Longer up pipe on EGR delete, question.
Doing an egr delete and just removed the old up pipe with the expansion joint. I noticed the new solid up pipe is about 1/4" longer than the old up pipe. Is this normal? Is it possible the old up pipe shortened a little after it was removed? I know there is an expansion joint in the y pipe, so perhaps it compresses to fit.
Thanks for the input.
The flex joints are designed to stretch a little. The OEM can stretch a little, the aftermarket versions like Vibrant are designed to stretch quite a bit.
The flex on the y-pipe can make upa little of difference, but not much. Hence why so many of that particular flex joint crack when combined with solid passenger up-pipes.
Josh
Josh
