6.9 starting then dying
If that works do you think the 1/4 tank pickup has broke off or just ran empty cause I put 300 miles on one tank and the tank selector switch has went out possibly
Received 3,102 Likes
on
<<<@!1!@>>>
If it works, then your selector valve is bad. Also, since you ran out of fuel and still show about 1/4 tank, the "showerhead" on the bottom of the pickup is broken off. So you can't get all the fuel out of the tank. There are two fixes to this: one is to drop the tank (or pull the bed) and replace the showerhead, or the second is to make your own by getting a piece of fuel line, notching a "V" into the bottom of it, and then putting it on the pickup line without a clamp and pushing the pickup down into it's place. That should make the bottom of the tank push the fuel line up on the pickup tube so it's just high enough to reach down to the bottom of the tank. Then pull the pickup back out, put a clamp on the hose, and re-install everything.
Myself, I prefer the showerheads. They're easier to do and only cost about $30.
<<<@!1!@>>>
Myself, I prefer the showerheads. They're easier to do and only cost about $30. Amazon.com: E5tz9j306ba Oem Diesel Ford Fuel Tank Sender Pickup Screen/Strainer: Automotive
