leveling kit - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
leveling kit
Old 10-25-2014, 05:17 PM
brangus82 brangus82 is offline
brangus82 is starting off with a positive reputation.
leveling kit
Anyone put one on a f350 crewcab pickup. I have a 2015 2wd with the 6.2. Is it a spacer or taller spring? Easy installation? Cost? Thanks
Old 10-27-2014, 05:11 PM
itskindalikethat's Avatar
itskindalikethat itskindalikethat is offline
itskindalikethat is starting off with a positive reputation.
Quote:
I put a Daystar 2" leveling kit on my '13 F250. jack up the front end, remove the front spring retainer, place new rubber spacer underneath, and use longer bolt to tighten back down.
I recommend Bilstein 5100 series shocks!
Old 11-08-2014, 08:20 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Leveling kits come either spacer or new replacement spring. I suppose it depends on how much you want to spend.
Good luck with your setup.
biz
o2 sin deepswag1889 Ranger & B-Series 0 09-26-2014 08:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
