Extruded U-nuts - Where to buy?
I can't find anyone that sells the extruded u-nuts used for the front fuel tank straps and skid plate. I have found a 3/16" one that will work to replace the M10 for the straps, but I can't find anything that will work for the ones on the skid plate. They are M8 and have 1-3/8" from the center of the hole to the inside of the 'u'.
Does anyone know where I can find them?
Close, but I need the center-hole-to-edge dimension to be more like 35mm, 21mm is way to short. I need 5 of them. I'll post a picture when I get home. I might just have to rig something up.
I broke one of these on each of our '95s front tanks. Outer edge of the skid plate, in particular. Since it happened on the spot and I wanted to get it back together without waiting for a part to be shipped, I managed to slide a regular nut up into of the frame, and had just enough finger to hold it while I started the bolt from below. PITA, but it worked.
on
1 Post
I thought it looked like I could do that. I actually broke the ones toward the rear of the truck.
I honestly can't tell for sure. I don't think so, but I'm going to have to stop by the Ford dealer so I'll have them run that number.
But yeah. Fastenal should be able to get those for you
Yeah it was a first job right out of college. I didn't bleed blue like the rest of them and finally got out. I had accounts in my territory that were run through a different store and they would not give them to me. After I left they turned them over to the new GM. Oh well it was good job experience for a first "real" job. They won't be such a profitable company for long with everyone ordering online and free shipping because they won't offer that.
I realize this is an old post, but I found some additional information that may help others down the road that also find it like I did.
I found a part in Auveco's catalog that seems like a match to the M8-1.25 extruded u-nut used to mount the skid plate. This one has a ctr-of-hole-to-edge measurement of 28.5mm which appears identical to the OEM one I've measured. The Auveco P/N is 19644.
Here's a link to an online retailer I found that sells them in a pkg of 15 for $18.24. GM Extruded U Nut M8-1.25 Scrw 1.7mm-5.5mm Rnge
I found the Auveco catalog (PDF) here: https://www.auveco.com/download/cata...co_catalog.pdf
Page 109
Page 109
packagerjr
Appearance & Dress-Up
02-06-2018 12:03 PM
supercabfreak
02-22-2011 07:30 PM
