Premium Sony Audio in 2015 truck
Hey y'all. I know this is a 6.7 forum but, well, you know.
I need a wiring diagram and color key for wires for the Sony sound system.
I want to know what signal and power is behind the rear seats at the amp and sub.
I also want to know the wattage of the amp that is back there.
How do I find this info?
Please be sure to share your results as I'll be doing a similar install in the next few weeks. Cheers
Hey ruschejj:
I have a 2013 with Sony Audio System and it is different from non Sony System and even the Premium Audio System in my 2008. When I first got my 2013, I didn’t think that it was as good sounding as my 2008 and after research I have since adjusted with control settings to my liking that I could live with. I did have a link back then from an Auto Audio Site and when I find the link, I’ll post it.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
1) I have a wiring diagram but not able to post it, maybe someone else could. From the diagram, the Subwoofer Amplifier on a Sony system doesn’t have its own power source like a non Sony system. So really it is just a Bass Speaker, the thing is that this speaker has two separate bass signals going to it.
<o></o>
2) The signal to the rear bass speaker is from the Audio Signal Processing Module (DSP). As I posted above, it is two bass signals. The SUB signals SUBW 1+ is VT-GN and SUBW 1- GN-WH. SUBW 2+ is WH-BN and SUBW 2- is VY-OG. Since these wires are connected directly to the bass speaker I would not believe that a bass amplifier is behind the rear seat. This might not mean that the there isn’t a 12 volt power source for a non Sony System there?<o></o>
3) Since the DSP is fused at 20 amps to power (run) all the speaker’s, I’m assuming that the whole system can put out not more then 240 watts. <o></o>
4) Again I will try to find the link. If we knew what you were trying to do, we could maybe be more specific.<o></o>
<o></o>
<o> </o>
<o></o>
<o></o>
Ok, thanks much mpd
What I want to do is unplug the amp that is behind the rear seat attached to the sub enclosure.
Then I want to use the existing wiring to feed my own amp, and feed my own subs.
So, in theory, I would just be swapping out what's there with new stuff. Fosgate 250w amp and twin kicker 10" subs.
Obviously, I will run a new power line from the batt.
My hope is that I wouldn't need to re wire all the speaker signals, just use what's already there.
Just to add: I’m just guessing with the information I have. I would contact Fosgate to be sure.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
The Sony DSP has the subwoofer amplifier within. It is set up (configured) as a DVC Subwoofer output signal. One signal is the true low bass signal and the other is to give the bass speaker a better range (high and mid bass). I’m not sure if you can use these signals as an input to the Fosgate amp, but I can’t see why not.
<o> </o>
Bigjeffs350
12-20-2018 07:47 PM
dono
06-18-2007 05:50 PM
chuckssports
01-12-2006 01:24 PM
Cool1996
22
11-09-2005 02:37 PM
