92 f250 5.8 Sputtering backfiring
Old 10-25-2014, 12:04 AM
bigdaddy coolbird's Avatar
bigdaddy coolbird
bigdaddy coolbird is offline
truck was running like a dream it went hunting and just quit. Have recently changed plugs and wires. Drained gas tanks and replaces fuel pumps, filter, fuel tank relay fuse, in dash tank selector switch, cleaned out air filter. Put clean fuel in engine turns like it has no equal. Used some gas to prime, bled fuel lines, fuel all the way up to injector rails a constant flow of fuel to there however when primed starts idles smooth until prime burns off feathered gas peddle to keep idling cough sputter bang. when I stopped to feather the engine idle smooth again then dies,
Old 10-25-2014, 10:17 AM
subford's Avatar
subford
subford is offline
Does sound like low fuel pressure.
Need to put a fuel pressure gauge on it and see what you get.
Do you have a stock fuel system or has it been modified?
Shawndodd1970
07-13-2018 07:56 AM
jamesadams
07-21-2012 11:49 AM
Slackdawg05
03-09-2010 06:42 AM
grelch
11-04-2007 10:16 AM
scooter_1968
11-21-2003 02:34 PM
Quick Reply: 92 f250 5.8 Sputtering backfiring
