Edelbrock 4 bbl carbs
tinman, if it's a newer clifford manifold, it should have 2 barbs you plumb inline with your heater hose. The older manifolds require making a plate on the bottom of the manifold and plumbing heat into the plate. The newer manifolds with the coolant passage built in are inferior castings with porosity between the passage and plenum, so check for coolant leaks into the manifold. Been there, done that, cut the coolant passage off and welded on a chunk of 1x1 aluminum tube.
Thanks, it seems like having the primaries outboard would make for more equal flow to all ports. This is an older open plenum intake without the water passages.
You can turn the primaries however you like. I have tried both ways. However, if you read the Offenhauser speil about the DP, it is clear that their intention, how it was designed and engineered, was to have the primaries closest to the engine.
My thoughts on the matter: Look at the oem intake runners. They are as large as the head passages. It is the carb opening that is the cork, the bottleneck. When a person intalls a DP they are changing the bottleneck from the carb opening to the runners. You get a large carb opening, but runners less than 50% (primary side) of the oem runners. That is idiotic. A person spends $ making the head flow, making the exhaust breathe, and then puts on an intake that restricts flow by 50%. Had I known better when I built my engine I would have gone with the C.
I will say, however, that I believe the DP will work better if you're running a large carb. Smaller runners mean increasing the velocity of the mix, thereby making the carb more responsive. It gets a stronger signal.
Zerojunk
10-25-2007 03:06 PM
