90 f150 302/EAOD to 90 f150 351/EAOD Swap
Have a 1990 f150 302/EAOD, wanting to swap in a 90 f150/EAOD.
I have searched it a gleening some info I think I know, but I would rather just know. Most swaps I have found were switching years of engine requiring a bit more work. I am fortunate enough to have a same year same trans donor. I am most concerned regaurding the computer and harness. What from the donor do I need? Engine(obviously) the trans I have is good, so I prefer to keep it. Flywheel and or torque converter? I know about the exhaust, easy fix. I would also be interested in swaping over from SD to MAF, but I can read up on that. I just want to make sure all the componets are gonna work together to get it up and running. Once I know what will work I may consider some mods prior to install, may even freshen the whole engine with a mild build. Any info appreciated, Thanx
Edit: E4OD Trans in both trucks
neverenoughtools
45
11-13-2018 11:00 AM
92_FlareSide
08-25-2005 12:25 AM
