2007 Power steering leak
Old 10-24-2014, 07:41 PM
matt167's Avatar
matt167
matt167 is offline
My 2007 F-150 just developed a power steering leak. pretty severe as it burned thru about a quart in 4 miles.. looks to be coming from either the power steering pump or the line behind it. It drips right onto the oil filter ( 4.6L ).. is this a common faliure? what part is likely needed? Truck just turned over 77k miles
Old 10-25-2014, 08:57 AM
1saxman's Avatar
1saxman
1saxman is offline
Sounds like a bad hose. Don't be shy - see if you can see a crack near the fitting by bending the hose. Maybe you can put some power steering fluid in, run the engine and see where its coming from.
Auty
Escape & Escape Hybrid
02-06-2009 09:09 AM
NorthCarolinaExpy
1997-2006 Expedition & Navigator
10-27-2005 04:18 PM
Quick Reply: 2007 Power steering leak
